1 members (Forty9),
66
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | The 4 speed tranny is original to the truck, the 235 engine is not. Clutch disc measured 9 and 1/8 inches when I took it out. Jim Carter catalog says normally would find a 10 inch disc with a 4 speed. What size disc and pressure plate should I go with if I replace both?
1951 Chevy 3100 5 window with a 1958-60 235 and original 4 speed.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I dought if the larger clutch will fit the flywheel. The 9 in will work OK unless you are going to work it hard or are hard on a clutch. A smaller clutch will shift easier & puts less wear on the syncros. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The only time I installed a clutch disc that was too large was on a 54 F%$# stationwaggon. When I turned the key and started the engine, lucky for me I was in reverse (parked in the garage)because the car started and leaped out of the garage. Pushing on the clutch petal had no effect. I had to go back to the parts store and get the right size. Ever try to drive across town without a clutch?
~Jim
| | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | According to the manual the flywheel on the 235 (58-62 off of a car) came with a 10 inch clutch. I took off a 9 inch (the disc anyway, which begs the question, can you have a 9 incgh disc with a 10inch pressure plate?) as the original motor was a 216. Carquest has one for the 235 for only 156 full kit, most likely its a 10 inch. Sorry for the dorky question.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1951purney, you can go smaller on the disc, than the pressure plate, but why would you? The older engines had a nine bolt pressure plate, the newer engines use a six bolt pressure plate, make sure you're ordering the one you need, 1954 appears to be the year of the change, hope that helps. | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | That is very helpful, i know this pressure plate has 6 holes on the one I took off, so if the plate fits and the 10 inch disc fits inside then I should be good to go right?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 1951purney, yes if the disc is the same size as the pressure plate, you are good to go. If your ordering a kit, it should/better come with matched components. | | | | | Joined: Apr 2008 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 38 | I think the PO used the 216 flywheel as the 235 was out of a car and has hydralic lifters leading me to believe therefore it didnt have a flywheel with holes for a clutch. That being the case the clutch I took out didnt match what the manuals said. Found a clutch shop here in Omaha that can refurbish everything for 100 bucks. Been in business for 70 years or some such. happy ending.
| | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | I had two flywheels and two used up clutches as I was sorting parts to re-do my 235 w/3spd. One was 10 inch, the other 11 inch. Since they both fit, I ordered an 11 inch clutch, thinking more is better since I will be towing. It's great having that bigger disc, but it takes three men and a small boy to mash the pedal and move the springs on the plate. I'll be the guy with an oversized left leg soon! | | |
