6 members (Otto Skorzeny, Charles in CA, DadsFirstPickup, J Lucas, Shade Baby, greenie-reddy), 112 guests, and 1 robot.
Topics128,147
Posts1,056,798
Members48,454
#50308 09/18/2005 8:26 PM
For all you people that have put a newer 235 and the origenal radiator will not clear fan . i used the radiator fron a 49 GMC 1\2 ton it bolts to the same bolt hole on the radiator support and is angled inward. and has a larger fluid capasity.
#50309 09/18/2005 9:35 PM
Riding in the Passing Lane
Great tech tip. smile
1972 Chevy c10 Cheyenne Super
#50310 09/18/2005 10:29 PM
I already knew Chevies make great parts trucks for GMCs. Hoodathought it would work the other way around?
#50311 09/19/2005 3:09 PM
You can use the regular water pump and not the short shaft one?
This should also work on the 261, right?
