3 members (2-Ton, 78buckshot, texczech), 236 guests, and 11 robots.
Topics128,078
Posts1,056,035
Members48,433
#502993 02/07/2009 5:07 PM
What year range of Stock Wheels will fit and work correctly as far as having the inner bumps to hold on the hub caps for a 66 Burb? Thank you for your help.
I'm not sure what year stock wheels came on the 1966 Suburbans. I have a 1966 GMC Suburban that I'm parting out. It has 6 lug 16.5 steel wheels with the inside clips for hubcaps. The tires are still mounted and I'm not sure what the width is. They look to be possibly 8.75 or 9.75 inches wide. If your interested in something that wide, I have (5) in real nice condition except for several layers of paint that should be blasted off. The inside and outside of the rims are not rusted or pitted. I haven't dismounted the tires but believe in between bead to bead would also be in good shape. I've also got some skinny stock steel wheels with inside clips off of my 1940 Chevy truck that are 16" six lug. Thanks Runningiron
Apprentice
Apprentice
66 would have outer clip-on style hub caps. you can use inner clip style youll just have to buy the earlier caps.
