| | | Forums66 Topics128,080 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 24 Apprentice | | Apprentice Joined: Jan 2009 Posts: 24 | th front hange was at the middle crossmeber before. i knocked the 2 center rivots from the bottom of the front cross member and started from there....
i also brought the rear crossmember[the one lifting the frame] forward to make a clean ending to the frame when i do the final length.
i also pulled the motor and tranny today. i put the motor up sale in the swap section but there is a lot of other little things i wont be needing like the starter pedal, the battery tray, the metal radiator shroud, so if you guys need something speak up.
56 2 ton, and never enough time.
| | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
