| | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 12 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 12 | My 71 C10 has original full wheel covers that "creep" (rotate) and pinch the valve stem. I've tried bending (carefully) the tabs. Welcome suggestions other than trading them for "mag" wheels or hub caps. | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | Try some minimum-strength LokTite on each tab. DON'T use Medium or Hi-strength, and be careful how much you use or it'll squish out and discolor the covers or rims.
I've used it on the fake plastic wheel nuts in the center of modern GM wheels, and it seems to hold them OK.
Hope this helps.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Get metal valve stems. They will contact them & stop. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | try some duck tape on the tabes
dan-pa
| | | | | Joined: Jan 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 47 | Try to file the tabs sharp if it has the sharp tooth style or you could add some teeth to your existing tabs. | | |
