| | | Forums66 Topics128,188 Posts1,057,332 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50271 09/17/2005 8:46 PM | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | http://cgi.ebay.com/ebaymotors/CLIF...1652QQcategoryZ36474QQrdZ1QQcmdZViewItem I'm just passing this along as some of you may be interested... it will be gone in a couple of hours. For those who wish to put a 2 or 4 barrel carb and better mix & flow on your motors. The water heat manifold is needed for street use as this intake is not connected to the exhaust to heat the manifold as the stock ones are.
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
#50272 09/17/2005 9:08 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Is this information being passed on or did you have a question about it? Just curious.
-ftyler | | |
#50273 09/18/2005 2:07 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Yeowch! I paid way less than that for one a few years back. | | |
#50274 09/18/2005 1:22 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | Exactly a hundred bucks more than I paid for mine!!! But on the positive side it is 42.50 cheaper than getting one from Clifford Performance. -ftyler | | |
#50275 09/18/2005 4:47 PM | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | What makes it any different/better than a stock manifold? Different carb mounting?
#50276 09/18/2005 6:38 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The runners are designed for better flow, and you can put a 2 or 4 barrel carb on it. | | |
#50277 09/20/2005 4:04 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by Fumblin46: What makes it any different/better than a stock manifold? Different carb mounting? That one is for the newer series engine. Here is one for the older sixes. It does flow better, and makes an attempt at getting enough fuel to the end cylinders, but dual or triple carbs work even better. The problem is still that the intake runners are of uneven lengths.
Fred 52 3600 69 C-10
