6 members (tclederman, JoergK., Wally / Montana, 69 coupe, 3800GUY, 1 invisible), 81 guests, and 1 robot.
Topics128,188
Posts1,057,333
Members48,469
http://cgi.ebay.com/ebaymotors/CLIF...1652QQcategoryZ36474QQrdZ1QQcmdZViewItem
I'm just passing this along as some of you may be interested... it will be gone in a couple of hours.
For those who wish to put a 2 or 4 barrel carb and better mix & flow on your motors. The water heat manifold is needed for street use as this intake is not connected to the exhaust to heat the manifold as the stock ones are.
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
Is this information being passed on or did you have a question about it? Just curious.
-ftyler
Yeowch! I paid way less than that for one a few years back.
1954 GMC De Luxe COE
Exactly a hundred bucks more than I paid for mine!!! eek
But on the positive side it is 42.50 cheaper than getting one from Clifford Performance.
-ftyler
What makes it any different/better than a stock manifold? Different carb mounting?
The runners are designed for better flow, and you can put a 2 or 4 barrel carb on it.
Quote
That one is for the newer series engine. Here is one for the older sixes. It does flow better, and makes an attempt at getting enough fuel to the end cylinders, but dual or triple carbs work even better. The problem is still that the intake runners are of uneven lengths.
Fred
52 3600
69 C-10
