| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50234 09/16/2005 10:13 AM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I'm running a SB 350 with standard points type ignition. What is involved in switching to a GM HEI distributor as far as wiring? Is the coil integral in an HEI system? How is it connected into my truck with my current system? Is there just a single wire? If so, where does it go?
Just curious, as I've been considering making the switch and when it comes to electricity, I'm in the dark (pun intended). I don't want to go Pertronix as it doesn't seem to be a true high-energy electronic system. Rather it's just a replacement for the points, right?
As always, any help is appreciated. | | |
#50235 09/16/2005 2:42 PM | Joined: Sep 2005 Posts: 254 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 254 | its just one wire, my 1970 chevy with SB 350 was switched to HEI before i bought it and i looked at all of it cause i'm redoing the whole truck. but i had to redo it cause i cut the wire and don't know what i did with it so i found witch wire connected to the key for the ignition, gotta pull the plug of the key part and one says IGN so i just spliced the wire hooked my HEI wire on and ran it through one of the openings in the firewall now its been a little while since i looked at it bout 2-3 weeks but thats what i remember i'll have a look at it and let ya know if anything is incorrect | | |
#50236 09/16/2005 5:19 PM | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | Thanks for the info! Do you know if I run this with or without the stock ignition resistor? | | |
#50237 09/16/2005 10:14 PM | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | You don't need the resistor with the HEI. Redcoat | | |
#50238 09/16/2005 11:18 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Drop in the new dizzy and connect the ignition wires. Run a new wire, 12 gauge from the unfused ignition on the fuse block to the distributor. You no longer need the resistor or wiring that connected to the old dizzy, coil and starter. Remove, unhook, tape over or whatever your comfortable with. This is assuming you're using the coil in the distributor cap.
Fred 52 3600 69 C-10
