| | | Forums66 Topics128,213 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2002 Posts: 12 Member | | Member Joined: Sep 2002 Posts: 12 | hi does any won know much about holley carbs ive got a 70 sbc lt-1 z-28 factory alluminum highrise manifold i think these only came stock with holley carbs on them.question is will any holley carb fit on this manifold or do i need an adapter plate also im thinking of purchasing a 600 cfm part #1850-2 single pumper carb but guy has no idea what came off of will this carb fit on my manifold does any one know what this carb will fit thanks | | | | | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Hi, any typical Holley 4 bbl will bolt onto your manifold if the bolt pattern is 5-1/4 x 5-1/2 inches. A 600 is a good size for street use, the original 302 Z-28 had a 780 cfm Holley, good for racing, not so good for the street. | | |
