5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
hi does any won know much about holley carbs ive got a 70 sbc lt-1 z-28 factory alluminum highrise manifold i think these only came stock with holley carbs on them.question is will any holley carb fit on this manifold or do i need an adapter plate also im thinking of purchasing a 600 cfm part #1850-2 single pumper carb but guy has no idea what came off of will this carb fit on my manifold does any one know what this carb will fit thanks
Hi, any typical Holley 4 bbl will bolt onto your manifold if the bolt pattern is 5-1/4 x 5-1/2 inches. A 600 is a good size for street use, the original 302 Z-28 had a 780 cfm Holley, good for racing, not so good for the street.
