0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50188 09/15/2005 4:20 AM | Joined: Sep 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2005 Posts: 46 | I am replacing the kingpins in a friends '46 1/2 ton. There was a significant amount of play so I am considering going to a .010 oversize kingpin. Any idea how you determine if you need the oversized kingpin? The old bushings in the spindle feel tight with the kingpin off the truck. Thanks! | | |
#50189 09/15/2005 6:30 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can't go by the old bushings or pins. As long as the bushing fits tightly in the spindle, it will be ok. The 1/2 tons use floating bushings, that don't have to be reamed to fit the pin. The larger trucks have the bushings pressed in and then they are reamed to fit the pin.
#50190 09/15/2005 6:48 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | The oversize kingpins were made to take up the slop in a worn axle end, not the spindle. The bushings will still have the same O.D. has standard. If your standard kingpins fit snug in the axle ends, that's what you need. Someone a few years back had a post about making oversize bushings to repair worn spindles. It may be in the Tech section.
Bob | | |
