1 members (baldeagle),
37
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Just curious about what type of grease you "stovebolters" use on you trucks.
1952 3100 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Depends on what I'm greasin'. I generally use Lubri-Matic lithium for the steering, king pins, and spring shackles, Alemite Hi-Temp #2 in the steering box and U-joints, and the wheel bearings get Valvoline Val-Plex EP. I also Syl-Glyde on any rubber parts that require lube.
Bill Burmeister | | | | | Joined: Jul 2007 Posts: 224 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 224 | i use what ever the country store down the road is selling and it seems to change around sometimes its tan sometimes its blue and sometimes its red but its always greasy.philip | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I use John Deere TY6341 for everything--it is supposed to be the best multi-purpose grease Deere sells. | | |
