| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | I wanted to know what the performance difference would be if I installed split exhaust manifolds on my 1954 chevrolet 1-1/2 ton with a stock 1962 1/2 ton 235 sm 420 transmission w/a 2-speed rear. I like the sound of the split six and plan to route the exhaust through 4-inch stacks. the truck will be loaded with construction tools and may pull a trailer with a skid steer loader,etc. I heard that the split manifold may affect my bottom end torque but will increase my top end power. I plan to upgrade to a 261 later on. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | As long as the 4" stacks are just for cosmetic effect, and you use small-diameter pipes off the manifold flanges, the low-end torque shouldn't be affected much. Run pipes about 1 3/4" or 1 7/8" diameter from the manifold to the stacks, and adapt them to the larger pipes for visual effect. Any semi-low restriction mufflers will produce the sound you want, guaranteed to give you a headache if you drive it very far. Jerry
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | IMO: If it is sound you want I'd say go for it. But in my rig, the rear axle is so geared low in either position that it can't go any faster no matter what you do with the pipes. I've got plenty of motor it just can't go very fast but it will pull anything you want! | | | | | Joined: Jun 2004 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 66 | do the mufflers have to be 1-3/4" or 1-7/8" inlet/outlet? | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Not necessarily, but the pipes off the manifold flanges don't need to be very big or you'll mess up the back pressure and possibly draw cold air back to the exhaust valves as the pressure pulses cycle. A split manifold only has half the pulse frequency in each pipe as a single exhaust, and the pulses occur every 240 degrees of crankshaft rotation. That's what gives a split manifold six the characteristic "BRAAAAAPPPPP" sound, but it can also warp valves with cold air if the pipes are too big. Jerry
