8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert), 99 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
I am getting ready to install new kingpins and bushings for my 46 1/2 ton. Here is the question. Is there any significant difference in the nylon bushings and bronze bushings except the major installation differences, namely reaming to size on the bronze bushings. Any experience would be helpful.
Thanks!
Welcome aboard Tudorman. I didn't know nylon bushing were available. I do know the 1/2 bronze or alloy bushing do NOT have to be reamed. You can assembly the whole works with hand tools. The bushings and kingpins are a slip fit and do not require a press. 46 3/4 ton is a different story.
Yeah, Tudorman, welcome aboard. I recently replaced the kingpins and all on my '40 GMC. The brass bushings tapped right in and were sized to the new kingpins. Are you getting your parts locally at NAPA or something? I would go with one of the vendors like American Classic or Jim Carter, etc. The kit comes complete and there's no headache.
Neil
1940 GMC 1/2 Ton
Welcome Tudorman! I also recently replaced both kingpins. Got them from one of the regular vendors. Just like Neil and Rusty, I had no problem fitting the replacements... now getting the old ones out is another @#%@@*%#@ story!
Larry Bear
55.5 Chevy 3100 Panel
Stay away from the nylon bushings. They go in easy but do not last very long. Before you know it, you will be replacing them again. Do it once, do it right.
