1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#50002 09/11/2005 5:36 AM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | I recently installed a goodwrench 350 crate motor in my 61 apache. At about 75 miles into breakin I am experiencing an oil leak. This engine has a dip stick orifice on both sides of the block. I am using the drivers side orifice. The orifice plug on the passenger side seems to be seeping. How is the best way to seal this leak? | | |
#50003 09/11/2005 11:14 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | 2 plugs come with the engine. They are a different size for each side. Put a little RTV on the correct plug & tap it in the hole. Do you have addicate ventilation on the valve covers? I use a pcv valve on one side & use a vented oil cap instead of the cap that comes with the engine. Stant Oil-64 Ithink is the part number. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#50004 09/12/2005 2:37 AM | Joined: Nov 2004 Posts: 61 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 61 | Thanks I am using a pcv valve on one side and a vented cap on the otyher but did not use any type of sealant on the plug. I will try that. | | |
