4 members (Phak1, 2-Ton, Gdads51, Wayne67vert), 36 guests, and 1 robot.
Topics128,022
Posts1,055,360
Members48,420
#50002 09/11/2005 5:36 AM
I recently installed a goodwrench 350 crate motor in my 61 apache. At about 75 miles into breakin I am experiencing an oil leak. This engine has a dip stick orifice on both sides of the block. I am using the drivers side orifice. The orifice plug on the passenger side seems to be seeping. How is the best way to seal this leak?
#50003 09/11/2005 11:14 PM
Riding in the Passing Lane
2 plugs come with the engine. They are a different size for each side. Put a little RTV on the correct plug & tap it in the hole. Do you have addicate ventilation on the valve covers? I use a pcv valve on one side & use a vented oil cap instead of the cap that comes with the engine. Stant Oil-64 Ithink is the part number.
1972 Chevy c10 Cheyenne Super
#50004 09/12/2005 2:37 AM
Thanks I am using a pcv valve on one side and a vented cap on the otyher but did not use any type of sealant on the plug. I will try that.
