0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Does anyone have the page from the Factory assembly manual with a definitive exploded view of what goes where on the door glass frame? Specifically, is the outer rubber window seal wiper oriented up and to the outside? Does the channel in the rubber go inside next to the glass? Does it go over the glass setting tape? A picture would be great and appreciated.
Thanks, Mark | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | scanner's on the fritz, but I can tell ya, the rubber you reference is the "setting tape" for the door glass, and goes in the channel of the sash ... and yes it goes on [under] the glass so the flap is to the outside Bill | | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | Thanks Bill. If I understand correctly, setting tape isn't used on the bottom, the rubber seal wiper serves that purpose. | | | | | Joined: Apr 2006 Posts: 136 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 136 | BTW: If anybody can send me a scan of the window and door, maybe I'll get it back together some day.
Thanks, Mark | | |
