5 members (ShopRag, Phak1, Bill Hanlon, Otto Skorzeny, 3B), 116 guests, and 4 robots.
Topics128,034
Posts1,055,547
Members48,425
#495228 01/19/2009 10:29 PM
4D6
Offline
Apprentice
Apprentice
I have a 1946 1/2 ton. It has a 235 instead of the old 216.. My problem is I can't figure out how the throttle cable and choke cable hook up. This carb has a automagic choke... Ideas?
Experience is the ability to recognize a mistake when you make it again....
4D6 #495231 01/19/2009 10:42 PM
Riding in the Passing Lane
With the automatic choke you dont need a choke cable. You would have to change carbs to use it. The conversion kits are funky. The throttle cable has a bracket under a carb cover screw. It comes down vertically & the core goes in the hole in the throttle rod with a retainer on the end.
1972 Chevy c10 Cheyenne Super
4D6 #495246 01/19/2009 11:37 PM
4D6
Offline
Apprentice
Apprentice
Do you recommend changing the carb? I kept everything like the '46 was, except the engine. I got it with the 235 and it is good enough for me. It has real good compression too.
4D6 #495270 01/20/2009 12:38 AM
If it is working good I sure wouldn't change it unless you want it to be strickly authentic. If its not working good its still better to fix it then to change carbs. Which carb is on it. Roch. model B or Carter W-1 or YF? I may have a bracket to hook up the throttle cable. George
Y
Y Offline
Hey what some people do, especially if the carb has auto choke is use the spare choke cable to operate a remote valve that opens and closes coolant flow to the heater core- Just an idea if you have the recirculating heater without a cab mounted coolant valve.
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
Yelostn78 #497515 01/25/2009 10:06 PM
If you want a manual choke find the same model of carb that came from a truck and you can convert it to a manual choke,I think automatic chokes only came on the cars.
4D6 #497806 01/26/2009 4:44 PM
4D6
Offline
Apprentice
Apprentice
The one on there now is a Rochester. I think this 235 is a 1957 model from a car. Was there one made with a manual choke? That would allow the correct carb for the engine and still let the manual choke and throttle work.
4D6 #498695 01/28/2009 4:28 PM
4D6
Offline
Apprentice
Apprentice
The one that is on my 235 is a rochester B with the automatic choke. I found a Rochester B with a manual choke but when I try it the engine won't come up to full RPM.. Almost like it has a leak. I read a comment about one of those having a problem in the throttle shaft, but how do you tell a good one from a bad one?
