3 members (68ironhead, Gdads51, 1 invisible),
53
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,691 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | i have a 48 loadmaster i see no switch or vacume piece on the rear end. so i assume that it is not a 2 speed rear end. did some just have a single speed rear end or does it sound like someone has changed it?
remember rust is our friend
| | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Not all trucks had 2 speed rear ends. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Single speed is most common on 1.5 ton (4000 series) AD trucks, although a 2 speed could be ordered. Most 2 tons (6000 series) trucks had a 2 speed.
What model number truck do you have? ("Loadmaster" doesn't tell us much)
Grigg | | | | | Joined: Jan 2009 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 36 | its a 4400 series i do believe
