| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49699 08/29/2005 2:26 AM | Joined: Oct 2004 Posts: 27 Junior Member | | Junior Member Joined: Oct 2004 Posts: 27 | Is there any way possible that you can make a 4 speed on the floor a 3 on the tree(without Swapping tranny)?
Thanks Slade
If ain't broke Break it and fix it.
#49700 08/29/2005 2:47 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Not with a transmission with a top mount shift lever. | | |
#49701 08/29/2005 5:24 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You could do it. You can do anything. Sounds like you'd have to get the 3 spd. shifter linkage and the transmission as well as the transmission floor cover. If putting in the new linkage from the tranny up the column doesn't sound too complicated to you, switching the actual trannies isn't any different than R n'R'ing a tranny for a clutch job.
