3 members (55shaker, baldeagle, Napco Man), 98 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#49699 08/29/2005 2:26 AM
Junior Member
Junior Member
Is there any way possible that you can make a 4 speed on the floor a 3 on the tree(without Swapping tranny)?
Slade
If ain't broke Break it and fix it.
#49700 08/29/2005 2:47 AM
Not with a transmission with a top mount shift lever.
#49701 08/29/2005 5:24 PM
You could do it. You can do anything. Sounds like you'd have to get the 3 spd. shifter linkage and the transmission as well as the transmission floor cover. If putting in the new linkage from the tranny up the column doesn't sound too complicated to you, switching the actual trannies isn't any different than R n'R'ing a tranny for a clutch job.
