| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 20 Apprentice | | Apprentice Joined: Sep 2008 Posts: 20 | Does anyone know what later model steering column would be a direct fit for a 65 Chevy. I would like a tilt column with or without an ignition switch. I have a floor shift automatic and a terrible after market turn signal switch that has to go. The existing column doesn't have any wiring in it and it looks to be to far gone to repair without knowing what it cane out of. I have power steering that was installed before I owned the truck.
I was told some van columns would be a direct replacement but nobody know's what year range. Some wiring tips would also be helpful for the replacement column.
Any and all advice welcome.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | maybe just get a column fron another early 60's chevy. you can take it apart to change the wiring, it's not too hard. my 63 had the same thing i changed it back to a original type. i've always had the best luck with doing that. does it have to tilt? | | |
