1 members (NJC),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | whats the difference between a 230 and a 250? and how far can you bore out a 230 before you hit the danger zone?
thanks -chris- | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | Hey Chris, Did you mean to say a 235? If so there are a few differences, like engine mounting points, horsepower, the 250 weighs less, the 250 is a "newer" engine than the 235. And lots lots more... If you really mean a 230, then forget everything I just wrote because I've never heard of one of those. Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | A 230 has a 3.875" bore (3 7/8") and a 3.25" stroke
The 250 has the same bore and a longer stroke, 3.530". It should be possible to make a 230 into a 250 by swaqpping the crankshaft and pistons from a 250 into a 230 block. I believe the connecting rod length is the same on both engines, but the compression height will be lower on the 250 to make up for the longer stroke. A 307 V-8 piston will fit the 250, same diameter, weight, wrist pin size and compression height, but it's a flattop design where the 250 has a 1/4" dished top.
Either block should take a maximum overbore of .060", but .030" oversize will give a longer-lasting rebuild due to thicker cylinder walls. 60 over engines have a habit of overheating easily. Jerry
| | | | | Joined: Jan 2008 Posts: 14 New Guy | | New Guy Joined: Jan 2008 Posts: 14 | so i should be able to put a 250 crankshaft into my 230 which will make it a 250. thanks thats what i was looking for.
thanks -chris- | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Looks like a lot of the parts are interchangeable, bore and stroke are the same for the 153, the 230 and the 307, they just added a few cylinders here and there. Just grab a part and the chances are that it fits. | | |
