1 members (dgrinnan), 58 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
#49379 08/22/2005 2:45 PM
Junior Member
Junior Member
Hi all, I am looking for a crankcase oil breather tube for a 54-55 235 Six. PO put in a freeze plug.
Thanks, TJ
#49380 08/22/2005 3:31 PM
Tab Offline
I have some info on trashing the breather tube and installing a pvc breather. email me and I will send it to you.
pokerface (at) htcomp.net
delete my account and pictures
#49381 08/23/2005 1:17 AM
Tab,
Are there any benefits from doing this?
#49382 08/23/2005 2:01 AM
Custom Title
Custom Title
I have a decent one if you're still interested. Email me: [email protected]
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
#49383 08/23/2005 3:28 PM
Rich - Benefits include less pollution and no oil drip in the driveway, at least not from the breather tube.
Fred
52 3600
69 C-10
#49384 08/24/2005 3:51 PM
Has anyone put the PVC valve in? Please let us know what your experience was.
The instructions are to connect the PVC hose to the suction side of the intake (normally where the windsheild wiper vacuum comes from). Does the Offy aluminum 2X intake have a port for vacuum?
#49385 08/24/2005 4:54 PM
Yes, the Offenhauser does have a port. You can drill and tap another additional port so you can run the windshield wiper and use the PCV setup.
Edelbrocks have two vacuum ports.
Joe smile
#49386 08/24/2005 7:00 PM
tjHooker125 -
Jim Carter has a crankcase oiltube breather in the garage sale section.
here is the link:
http://www.oldchevytrucks.com/cgi/htmlos.exe/00986.3.623628955900022947
#49387 08/24/2005 7:45 PM
I've got a couple of them and since I'm in the middle of a rebuild am planning on converting to the PCV set up. I've read that in addition to not polluting, or smoking as your are driving when the oil sucked out of the road draft tube burns on your exhaust, or dripping in your driveway, doing the conversion gets you a slight improvement in gas mileage.
#49388 08/25/2005 12:47 AM
If you go the PCV route put one of those in line.
http://www.condensator.com/
it saves some gas and keeps the slug out of the engine. I was shocked when i cleaned the bowl the first time how much it was.
Frank
#49389 08/25/2005 1:23 AM
On my friend's 261 he put the valve in the breather, which has the exhaust tube removed. Vacuum runs off the intake tap, and around the front of the block.
[img]http://www.myoldtruck.com/gallery/files/2/3/8/Engineleft.jpg[/img]
[img]http://www.myoldtruck.com/gallery/files/2/3/8/Engineright.jpg[/img]
Fred
52 3600
69 C-10
