| | | Forums66 Topics128,169 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49379 08/22/2005 2:45 PM | Joined: Jun 2005 Posts: 1 Junior Member | | Junior Member Joined: Jun 2005 Posts: 1 | Hi all, I am looking for a crankcase oil breather tube for a 54-55 235 Six. PO put in a freeze plug.
Thanks, TJ | | |
#49380 08/22/2005 3:31 PM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | I have some info on trashing the breather tube and installing a pvc breather. email me and I will send it to you.
pokerface (at) htcomp.net
delete my account and pictures
#49381 08/23/2005 1:17 AM | Joined: Jun 2005 Posts: 38 Member | | Member Joined: Jun 2005 Posts: 38 | Tab, Are there any benefits from doing this? | | |
#49382 08/23/2005 2:01 AM | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | I have a decent one if you're still interested. Email me: [email protected]
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | |
#49383 08/23/2005 3:28 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Rich - Benefits include less pollution and no oil drip in the driveway, at least not from the breather tube.
Fred 52 3600 69 C-10
#49384 08/24/2005 3:51 PM | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | Has anyone put the PVC valve in? Please let us know what your experience was.
The instructions are to connect the PVC hose to the suction side of the intake (normally where the windsheild wiper vacuum comes from). Does the Offy aluminum 2X intake have a port for vacuum? | | |
#49385 08/24/2005 4:54 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yes, the Offenhauser does have a port. You can drill and tap another additional port so you can run the windshield wiper and use the PCV setup. Edelbrocks have two vacuum ports. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#49387 08/24/2005 7:45 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I've got a couple of them and since I'm in the middle of a rebuild am planning on converting to the PCV set up. I've read that in addition to not polluting, or smoking as your are driving when the oil sucked out of the road draft tube burns on your exhaust, or dripping in your driveway, doing the conversion gets you a slight improvement in gas mileage.
#49388 08/25/2005 12:47 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | If you go the PCV route put one of those in line. http://www.condensator.com/ it saves some gas and keeps the slug out of the engine. I was shocked when i cleaned the bowl the first time how much it was. Frank | | |
