| | | Forums66 Topics128,080 Posts1,055,952 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | Hi all, im currently rebuilding a 235 for my 58 apache. I am having trouble trying to pull the harmonic balancer off, i tried using a puller but it din't have any luck. it shows no sign of being center pressed but there is no other way for it to be put on. my next thought is to use PB blaster and hope it budges, but i am afraid ill break something, any suggestions? thanks. | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | What kind of puller are you using? The right one is a crowfoot-shaped one that uses the two threaded holes in the center of the balancer, and the puller screw bears against the end of the crankshaft. If you use a jaw-type puller on the outside, you'll tear the outer ring off, or damage it to the point it will separate when the engine is run again. If you're using a heavy-duty harmonic balancer puller, tighten it very firmly, then smack the end of the puller center bolt with a BIG hammer. Once the shock breaks the balancer loose, it should come off pretty easily. It's probably on too tight for penetrating oil to do much good.
As a last resort, use a rosebud torch to heat the center hub of the balancer while the puller is tightened down. That usually ruins the balancer, but it will get it moving so you can do the rest of the engine teardown. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If your balancer has hand crank lugs (don't know what year GM got away from them or even IF they got away from them) on it you're probably making the mistake of pushing against them. Put a 9/16" socket in the center of the lugs & push against that. If you've never pulled one it's not obvious what you should & shouldn't push against.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I found that smacking the end of the wrench with a hammer to emulate an impact wrench started the pulley moving. If you have an impact wrench, it will probably do the job for you.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | All good advice. Use the proper gear puller, crank a 1/4 turn, strike it sharply and continue cranking a 1/4 turn and smack until free.
Drew
| | | | | Joined: Dec 2008 Posts: 13 New Guy | | New Guy Joined: Dec 2008 Posts: 13 | ok well ill have to make a trip to the store but I think all i have left to do now is put the advice into action. ill keep you updated, thanks for all the input! | | | | | Joined: Jun 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 388 | Torque Wrench, Here is a link to the 1954 Shop Manual , showing the type of puller to be used. As others have said, make sure that the center bolt of the puller seats on the end of the crankshaft snout, and does not get hung up on the pulley hub. As Drew and others say, tighten the center bolt, whack the bolt head, repeat. I've never seen it fail. I recently pulled a pulley from a 1954 261 that had sat outside since 1962. Hoyt | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | my puller is like this one. I used my impact wrench and pulled mine off easily.Make sure you have it lined up straight and even. puller 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
