4 members (Shardean, Tstan7, 2 invisible),
94
Mod | | | Forums66 Topics128,022 Posts1,055,353 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49234 08/18/2005 11:58 PM | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | I have a 41 - 216 engine that runs, but when the pointer on the bell housing is aligned with the "BB" on the flywheel the engine backfires when reved-up. It also will not start when turned off. When I adjust the timing by ear and no back fire, the timing mark is way out of sight, past a triangle on the flywheel. Is the timing adjusted with or without the vacuum advance connected? If the distributor was put back in one notch off when it was rebuilt, would this give rise to all of the above?? Is the point gap of 0.018 correct? What would the dwell be? (is this the same as cam angle of 38 in the old "motors manual")
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
#49235 08/19/2005 2:21 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | I personally dont use timing lights just set it as far advanced as i can without spark knock or hard starting.as for the dist.being a tooth off it shouldnt affect where the timing marks align.if its a tooth off you will have to turn the dist.one way or the other to compensate for it so it will still be firing where it was before. if that makes sense | | |
#49236 08/19/2005 4:32 AM | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | dwell 28 to 30 deg.Or .015 with a filler gauge or a flap on a book of matches.Vacumn line disconnected and pluged so it don't suck air.set timming 2or 3 deg advanced of proper setting .This will compensate for worn fiber timming gears over the years.Setting by ear if fine if you got a good ear.Ha
dan-pa
#49237 08/19/2005 4:29 PM | Joined: Jul 2005 Posts: 25 Junior Member | | Junior Member Joined: Jul 2005 Posts: 25 | I enjoyed your reference to the match book flap. I used the flap many times in the'60s,worked very well.Thanks for the memories!
Arnie | | |
#49238 08/19/2005 4:39 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | First, see if the ball/pointer relationship is really top dead center for #1 cylinder. Take the #1 plug out, and probe for the piston with a piece of soft wire while you turn the engine by hand. When the piston reaches TDC, the ball & pointer should be close to aligned. If not, make a paint mark, etc., to indicate TDC on the flywheel when the piston is at the top. Jerry
