Drove the old girl home today, and have started fixing things that are wrong. I've been doing a lot of reading on the Stovebolt page, Gawd, this stuff is invaluable. Anyway - - -
This is a clean little truck with few ailments, and it has a decent operator's manual with it. It has what the manual describes as the "heavy duty air cleaner". It is supposed to be a oil bath air cleaner, and, of course, not only does it have no oil in it, but there are several holes in the bottom of the cleaner reservoir. Three of them are obviously pinholes or such, but one of them appears to be a 3/16" drilled hole.
My question: Is that one hole supposed to lubricate the felt washer underneath, or should I just go ahead and solder up everything so it doesn't leak and add a pint of 50w oil like the book sez?
fredstev
