7 members (Peggy M, Hotrod Lincoln, mason86, 1955 1 Series, Simon1954, 53again, Cosmo), 97 guests, and 0 robots.
Topics128,068
Posts1,055,883
Members48,428
#491719 01/10/2009 5:41 AM
Getting ready to order the origional looking wiring harness from YNZ. Any thoughts or tips on this matter from you pros before this rookie buys? http://community.webshots.com/user/53jimmy
The best things in life are FREE!
Ex Hall Monitor
Ex Hall Monitor
I used YNZ's product and recommend it highly. 'Taint cheap but worth the money.
Tiny #491791 01/10/2009 4:19 PM
Thanks Tiny, Remember I'm a newby at this. Any problems with the lengths of the wires or how they are marked for placement?
53jimmy #491915 01/10/2009 11:53 PM
Ex Hall Monitor
Ex Hall Monitor
Nope, every wire is marked on both ends & you'll get written instructions for every wire like (connect wire S3 to terminal X on the light switch and terminal Y on the taillight). The wire will be marked S3 on both ends. You'll also have a wiring diagram & drawn images of the terminals on the switches where necessary. You only need to be smart enough to know that the short end of the harness goes under the dash and the long end goes through the firewall. You'll even get new sockets for the lights and/or new contact buttons to rebuild sockets (at least I did).
