7 members (baldeagle, Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna, pkr), 62 guests, and 8 robots.
Topics128,018
Posts1,055,342
Members48,419
#489529 01/03/2009 7:35 PM
My truck had originally a "GUIDE" spot light with a mirrior, my question is was there ever one for the right passenger's side ? I've got the acc. installation manual, it shows only the left driver's side, now can a spot light's mirrior be converted to use on the right? are they basicly the same as the one used on the passenger car?, BILL
BILL #489641 01/04/2009 1:49 AM
Sir Searchalot
Sir Searchalot
if you search you may find where we have discussed this and there is some info which may answer your Q. You will see it under "factory spotlight in task force trucks".
