| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | My truck had originally a "GUIDE" spot light with a mirrior, my question is was there ever one for the right passenger's side ? I've got the acc. installation manual, it shows only the left driver's side, now can a spot light's mirrior be converted to use on the right? are they basicly the same as the one used on the passenger car?, BILL | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | if you search you may find where we have discussed this and there is some info which may answer your Q. You will see it under "factory spotlight in task force trucks".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
