1 members (1 invisible),
100
Mod | | | Forums66 Topics128,265 Posts1,058,366 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 54 | I'm building a '57 Cameo. It looks like the Cameo bed parts are available through Jim Carter. Does anybody have sources for the Apache trim that would go with that? Thanks, regmudd | | | | | Joined: Aug 2003 Posts: 65 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 65 | As I recall, the Apache name didn't come until 1958. Prior to that, the Cameo was a 3100, but in 57, I believe that the fender emblem showed the actual model number, 3124.
51 Chevrolet Canopy Express 02 K25 Duramax Crew Cab
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Steve's right, "Apache" was the designation for light trucks [1T and under] that started in 1958 ... and there's no repro of the Cameo 3124 fender spear [used in '57 only], e-bay or the parts wanted here is your only possibility
Bill | | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy regmudd, the Cameo 57 fender spear "3124" is available from the Truck Shop in Orange California their p/n is 57-01506 $236.00 per pair, hope that helps. | | |
