| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48682 08/04/2005 8:46 PM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | I was told I can take my drums that are 6 lug and make them into 5 lug drums. Is this a good idea or not? Seems to me it would make them weak. what do you think | | |
#48683 08/04/2005 10:09 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the early Chev car hubs fit the TF spindle so all ya gotta do on the front is find early 50's car spindles and drums - the rear would need to be completely swapped out for newer car rear w/ 5 studs
Bill | | |
#48684 08/05/2005 2:35 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | You can have your hubs and axles drilled for 5 hole with no problems.if your working with an early 50s truck 53 or 54 car hubs will go right on but you have to use the truck inner bearing and race. | | |
#48685 08/05/2005 5:33 PM | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Yes you can have your axles drilled for the Chevy 4 3/4 bolt pattern.Had mine done at Moser Engineering in Indiana. | | |
#48686 08/05/2005 5:58 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | If you decide to swap the rear end to go to a five bolt pattern, or do a front disc brake conversion (very easy), I would suggest using the 5 lug on 5" pattern instead of 5 lug on 4 3/4. I'm in the process of that right now and have found many GM 10 bolt positraction/limited slip differentials that are 62" from wheel mount surface to wheel mount surface, which is what my truck is, but they have all been '5 on 5'. They are all under Chevy Caprice's, Caprice Wagons, Olds Cutlass Supremes, Pontiac Grand Prix's, and other large sedans/coupes. I haven't had any luck at all finding a posi 5 on 4 3/4.
If you want to keep your stock axel and convert you might look at speedwaymotors.com, they have a rear axel conversion to DISC brakes for around $300, not including a new master cylinder.
#48687 08/08/2005 12:28 PM | Joined: Oct 2004 Posts: 40 Apprentice | | Apprentice Joined: Oct 2004 Posts: 40 | thanks everyoun for your help
Kevin | | |
