9 members (TUTS 59, Millenimech, cmayna, Hanks custodian, Otto Skorzeny, Oswald, Cosmo, Bill Hanlon, gswbbc),
89
Mod | | | Forums66 Topics128,042 Posts1,055,522 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have a 37 GMC an was wondering if and what anybody has done for stereo/radio speaker location. I'm tring to get some Ideas for when I get to that part of the build thanks
1938 Gmc 1/2 ton
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I'll be watching to see as well. It will be a while but it is never too late to get some good ideas!
~Jim
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I located the stereo in the glovebox. Speakers beneath the dash, and in cab corners just below the seat back. Antenna mounted under the running board on the frame. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Ammo cans make great speaker boxes! BTW, those are 7.62mm ammo cans used with M-60s. The M2-A2 .50 cal ammo cans are a bit too wide to fit into cab corners. They make great toolboxes, though!
Bill Burmeister | | | | | Joined: Dec 2007 Posts: 180 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 180 | I located the stereo in the glovebox. Speakers beneath the dash, and in cab corners just below the seat back. Antenna mounted under the running board on the frame. great idea for the antenna. nice looking 40 you have. I am helping a friend build one. do you have any details on the build? | | |
