2 members (36High, Wally / Montana), 212 guests, and 5 robots.
Topics128,078
Posts1,056,052
Members48,433
#486261 12/25/2008 3:53 PM
WAS WONDERING IF ANYONE HAS A SUGESTION ON WHAT MOTOR WOULD WORK BEST IN OUR 49 PANEL VAN IF WE WERE TO USE THE OLD FRAME
If you want to do the easiest "upgrade": Tech Tip - Engine Swap
Leo Offline
Moderator
Moderator
You can get many suggestions and there is not a right or wrong way of doing it. My suggestion is simply my opinion, for what it's worth. The original low pressure oiler will not be a good choice. So now the options are many. Another stovebolt six will bolt in very easily. I was exactly in your position a year ago. I found an old 261 which are quite plentiful in Canada and shouldn't be hard to find for you either. It cost next to nothing but the rebuild was around $2000.- . It will look very much like the original, but will last longer and still has lots of torque and horses. For me, because I like to keep things pretty much as they were, this is the right engine. I will not second guess my decision.
What are you going to use the panel for? Best has a lot to do with being right for the purpose.
If you're going to park it out back and ignore it (like my 1-ton panel), it doesn't need a motor at all.
I PLAN ON MAKE THIS A DAILEY DRIVER FOR WORK
Leo #486395 12/26/2008 12:02 AM
Thanks for the ideas
Fire 12
As said above it is best to start with a vision on what the end will be. A daily driver to some is an upgrade to 235/261 while to other a daiy driver is highway speed on the interstate with a V8 of some variety. Unfortunately it also depends on the budget as more motor means other driveline changes like brakes, rearend, etc. The good news is its your truck and you get to make those decisions. Go slow and keep the "fun" of restoration in the project. Good luck.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
Later model 6 ie 235 or Small Block V8 is the way to go. However you are only half way there if you do not go to a lower rear end ratio ie 3.55 with a 6.
