3 members (68ironhead, MickeyP, 1 invisible),
82
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,624 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | Well it is finnally happening. I have made some progress on the old FT. The cab wood is glued and screwed. Have some sheet metal hung and fastened. Doors are up next and then once square with running boards, body mounts will be secured and then PAINT the cab. Check out the last three photos of album.
Last edited by Peggy M; 07/09/2024 10:42 PM. Reason: added full truck year to help with searches ;)
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | I agree it looks good. I have two one 34 and a 35 army truck. I just did the wood to. Someone should have told you not to glue. to late. the cab wood is designed to flex to some degree and also to expand when needed. The glue will either crack or the wood will.
I hope that does not happen. My truck is a bit further beyond but, now on hold for winter as it is outside in the snow now.
we just had 2 ft dumped on us with another 2 on sunday. here in the Northeast.
do you have any pics of what it was like before you started?
Keep up the good work Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | | | | | | Joined: Feb 2007 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 100 | I have the doors on and the front clip is just about to bolt the frame. I will get some updated pics in the ol ablum. Thanks for all of your support. As most of you know more than I, this is a project that needs lots of patience and help from fellow BOLTERS! | | | | | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | | | |
