3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#484983 12/22/2008 2:39 AM
I have a 1970 GMC 3/4 ton with a three speed transmission, I am wanting to change it to atleast a four speed or maybe even a five speed transmission. What would be the best transmission for this aplication? Where can I get one for this truck and would it mount up to the origenal bell housing? The truck has a 350 in it so I thought it might be an easy swap out.
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
How do you intend to use the truck? Transmission choices affect usability and drivablilty and need to match your intended use.
An SM465 - 4 speed from that same year would bolt right in
I intend to do moderate hauling with the truck nothing to heavy. I forgot to mention that my truck has a automatic transmission. Was there an automatic 4 speed?
If you want to go from an automatic to a standard, the best thing to do is to find a parts truck of the same vintage with the desired transmission. That way you will have a clutch, linkage and etc.
700r4
Now you're talking a different tune. Go to a 700R4. You will need a different torque convertor, will probably have to cut the driveshaft,and you'll need to install a switch to lock up the convertor. My suggestion is to find a 88 or newer 700R4,as they have a solenoid in them to give them a more positive shift.
It is sounding like it might be easier to go to a manual 4 speed or just stick with the three speed auto. Which would you recomend? I am not planning on doing much highway driving and if i do I am only going 60 in this truck. I could live with the three speed just thought there might be a four speed for this year of truck.
Stay with the auto that's already in it, it's mnuch stronger than a 700r4. Or is you do want to upgrade to an overdrive automatic, take a look at the 4L80E, which is the overdrive equivalent to the TH400 that you already have. Another option would be a gear change. Being a GMC, you should have a Spicer 70, whcih has very good gear availability if you want to change the ratio (3.55-3.73 would be a good range).
Bill Burmeister
