6 members (Jon G, baldeagle, Oswald, fonz8261, Hotrod Lincoln, 1 invisible), 55 guests, and 3 robots.
Topics128,015
Posts1,055,334
Members48,419
#484263 12/20/2008 2:31 AM
Truckernix, I was reading your post from back in 2006 where you used a 1.2 ohm 40 watt resistor to drop 12 volts to 6. How has that worked out? Have you had any of the problems with tube life that some folks predicted? I was just curious.
I was experimenting on the bench to see what value was needed. My truck is still 6 volts. If I change over to 12 volts some day, I might go with the resistor method. The reason for going that way is to keep the radio in it's original form. They can be converted to 12 volts but that requires a donor transformer from a 12 volt radio.
1951 1 Ton Completed
Moderated by  truckernix
