| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 9 New Guy | | New Guy Joined: Apr 2007 Posts: 9 | Looking for advise on replacing motor mounts in my 58 chevy 1/2 ton. It has the original 283 with the original type mounts and I installed a 350 turbo trans. with the after market crossmember. I'm getting engine roll and the rubbers on the original mounts are slipping. Is there a mount system out there that wont cover the oil pan. I am aware of the ones that Jim Carter and Chevy Duty carry. Any suggestions will be greatly appreciated. THANKS.
dave hudson
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the only thing you can do to avoid the tube right across is fab your own welded setup to use the side mounts, the front mounts with an auto trans just won't do
Bill | | |
