| | | Forums66 Topics128,155 Posts1,056,868 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | How much "play" should the brake pedal have in relation to the bushing that connects it to the master cylinder unit. I don't know if its ever been changed, and it seems to have too much room to wiggle. If I should replace the bushing, where can I get one. Thanks. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It should have no play in it in a perfect world. I would check with Jim Carters for the part or Chevy of the 40's. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | Stuart is correct!  No play would be ideal. You will have to mess around with the linkage to the master clylinder. I have dismantled my master cylinder and am in the process of cleaning and rebuilding it. It was in sad shape. I bought a rebuild kit from JC. To help take the "side to side play" out of the brake pedal I ordered, and just received, bronze bushings from Jim Carter. Had to be back ordered but looks like their going to fit with no problem. I ordered the pair so I can also replace the clutch pedal bushing. Still have to remove that stubborn steel pivot pin on the clutch side. I've been out of town and hope to resume my efforts after Christmas. As far as the clutch pedal is concerned, my shop manual calls for a 3/4 inch play before engagement. Just an FYI. My clutch pedal had a slop of about 2 inches!! Way too much!  Can't wait to redo my clutch and install that brand new throw out bearing!!
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | Thanks for the info. I'll be ordering them from Jim Carter. | | |
