0 members (),
155
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 1 New Guy | | New Guy Joined: Sep 2008 Posts: 1 | i have a 52 with a 55/57 engine. The truck came without a drive shaft, and was wondering if anyone could tell me what kind of drive shaft would work on this setup? Thanks! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | i have a 52 with a 55/57 engine. The truck came without a drive shaft, and was wondering if anyone could tell me what kind of drive shaft would work on this setup? Thanks! I guess your engine is a six probably a 235. I believe you can get all the help you need here but you need to cough up some more details.
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Cheapest would be pull on from a junk yard from the same length and approx year truck with the same transmission.
Better quality would be from your local driveshaft shop, but only if they will dynamically balance it. This is still relatively cheap, and new with no flaws.
Grigg | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I paid a little over 100.00 to have mine built. I wasted a lot of time searching the junk yards with no success. The problem with junk yards is, they use fork lifts to move the vehicles around and that usually bends the drive shaft.
~Jim
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Assume, the torque tube rearend has been changed out? Is the rear axle centered in the wheel well? Take some measurements and you might get lucky and find the right length at the "wrecking" yard. In the old days they used to pull them and stack them up by manufacture. Now days with front wheel drive some drive shafts are getting rare and hard to find. The last one I had built with new joints cost about $135.00 | | | | | Joined: Nov 2013 Posts: 12 New Guy | | New Guy Joined: Nov 2013 Posts: 12 | I have a wobble vibration at about 45 mph and think its either the trunion or worse, should I repair or replace with one piece drive shaft? I have the original closed front, open rear two piece shaft | | |
