3 members (cmayna, mk72, Paul_WNC), 38 guests, and 7 robots.
Topics128,012
Posts1,055,321
Members48,419
#48239 07/26/2005 1:06 PM
I am going to be replacing my suspension and frame member bolts and I am not too sure where I will be able to come up with the exact replacement bolts I need. Does anyone have a good source for replacement hardware? Can I substitute a Grade-8 coarse thread bolt/nut of the same dimensions for an original fine threaded bolt/nut (1954)?
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#48240 07/26/2005 2:30 PM
cujo8,
If you want original style (thread and grade) bolts (or stainless replacements, where safe), The Nutty Company has as good a selection as anyone:
Totally Stainless has a good selection of fine-theaded bolts/screws and a wide variety of cap styles (no clutch-head, though). If you are interested in stainless, read their page on "About Stainless Steel).
Tim
#48241 07/26/2005 2:51 PM
Any good parts house, NAPA, for example, should have a full range of grade 5 & 8 bolts & nuts in both thread pitches. Doug
#48242 07/26/2005 4:08 PM
Thanks for the ideas and links. Now I need to spend the time to make up my shopping list.
#48243 07/26/2005 10:03 PM
You can also try McMaster Carr at www.mcmaster.com. They've got everything.
Country Roads, West (By God) Virginia
http://community.webshots.com/user/geezer
#48244 07/26/2005 10:17 PM
Riding in the Passing Lane
My local Ace hardware has as good selection of grade 8 as anywhere
1972 Chevy c10 Cheyenne Super
