4 members (Rich'sToys, gswbbc, Hanks custodian, 1 invisible), 129 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#481215 12/12/2008 12:41 AM
Hello, would like to switch from points to electronic ignition and was wondering what was the least expensive way to go with this. I have a 250 engine in a 63 C-10. Thanks.
Jay McIlwaine
Find a 1975 or newer 250 and grab the HEI distributor. May cost you $50 at most from a salvage yard.
I found a 79 HEI dist off a 250 that Im using in my 235. I just got the collar filed off and now Im waiting for the two piece collar in the mail to try it out.
You might want to check out a Pertronix electronic ignition set-up. I have used them and had great luck. If you do have a problem you can always carry the point set-up to put in to get you back home.
I also have that setup in my 4cyl. Chevy II boat Dist. as Don Stocker and it works really great.
62Blue.
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
