1 members (TooMany2count), 81 guests, and 4 robots.
Topics128,126
Posts1,056,354
Members48,441
#481409 12/12/2008 4:38 PM
Can anyone help this worn out parts procure-er? Where can I find replacement lines and fittings for the original oil gauge to block plumbing?
Dave
GMCdp #481453 12/12/2008 8:12 PM
3B Offline
Hy GMCdp, how much of the stuff do you need? I assume we're talking about gauge plumbing for a GMC engine. The lines are just 3/16", then there is a special tee at the front of the engine, and a small section of rubber flex in the line that goes up to the cab.
3B #482156 12/14/2008 7:18 PM
Nevermind. To my surprise, Napa had the fittings and copper tubing. Just in case anyone else has a problem with this, the fittings were called threaded sleaves from an Eaton catalog and the line was just copper tubing (whatever the size was, probably 1/8" OD). They also had the adapter to 1/8" pipe thread for the block connection.
Dave
