5 members (MickeyP, papas52, dt235sd, GA Boy, dgrinnan), 76 guests, and 1 robot.
Topics128,169
Posts1,057,035
Members48,458
Where can I get speedometer gears for my 1946 Chevrolet 3/4 ton truck?
Does anybody make these parts?
If you have a 3 speed, this MIGHT be the part you're looking for. I've been searching for one for a 4 speed, 1/2 ton but no luck. Go to www.obschevy.com and type in the search engine 605062. I'm not sure that is the correct one, because the Chevy Master Parts Catalog calls out a 605063 for a 1946 3/4 ton (DR).
Good Luck
46Possum
Just noticed they stock the 605063, as well. If you have a 3 speed, this is the one for you, I think!???
I need the gears for a 4 speed 3/4 ton truck
