10 members (5 Window 9434, cmayna, 78buckshot, Samantha, DJMTruck, dt235sd, Opelika Tom, Gdads51, HandyAndy, 1 invisible),
94
Mod | | | Forums66 Topics128,062 Posts1,055,847 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 19 New Guy | | New Guy Joined: Apr 2008 Posts: 19 | I am completing the complete restoration of a '44 Chevy 1 1/2 ton flatbed. In overhauling the two-piece drive shaft (single speed), I have been unable to locate a new carrier bearing, New Departure #5207. Anyone got any ideas? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy JLREA, are you looking for just the bearing, or the whole carrier assembly? The Bower cross to that bearing number, without any letters on either side of the number, is 5207W, hope that helps. | | | | | Joined: Sep 2008 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 32 | I got a complete carrier bearing assy and 2 piece drive shaft from my 47 2 ton COE if it helps you any | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | I sent you a E-mail about where to get that bearing. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | im going to need one soon. i wonder if that's the same one for a 40 gmc one ton? | | | | | Joined: Sep 2008 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 32 | Check it out and if mine will work your more than welcome to it. | | |
