1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | I'm thinking about having some shift lever boots fabricated, since I can't seem to find any. Is anyone else interested in one? It will be easier to justify the tooling charge if there's demand from others. Speak up if you're interested! | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are you looking for a factory repro or just something that will work? 4wd hardware has quite a few options for transfer case shifters. http://www.4wd.com/search.aspx?PN=1&kw=shifter+boot
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | The design is somewhat unique in that the shift lever spends most of it's life (in 2-Hi) parallel to the floor, horizontal. When it's in 4-Low it's vertical next to the seat. The boot accomodates the full 90 degree range of motion. The bellows convolutions are offset so it appears to be at ~45 degrees in it's natural position. The designs I've seen available are typically for vertical shift levers.
For about the past 25 years Big Tan has had the transfer case shifter sealed by a thick piece of rubber with a slit ~12" long. It works well enough to seal the air from below from coming into the cab. If worst comes to worst, I'll continue with this. But if others are interested in the same thing, it may be worth considering a custom fabricated part. | | | | | Joined: Aug 2008 Posts: 10 New Guy | | New Guy Joined: Aug 2008 Posts: 10 | Here's a link to some pics if anyone is interested: '64 Transfer case shift lever and boot Drop a line if you're interested in getting one. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | i need 1 for my 1960 k-20 | | |
