0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
I'm thinking about having some shift lever boots fabricated, since I can't seem to find any. Is anyone else interested in one? It will be easier to justify the tooling charge if there's demand from others. Speak up if you're interested!
Are you looking for a factory repro or just something that will work? 4wd hardware has quite a few options for transfer case shifters.
http://www.4wd.com/search.aspx?PN=1&kw=shifter+boot
Paint & Body Shop moderator
The design is somewhat unique in that the shift lever spends most of it's life (in 2-Hi) parallel to the floor, horizontal. When it's in 4-Low it's vertical next to the seat. The boot accomodates the full 90 degree range of motion. The bellows convolutions are offset so it appears to be at ~45 degrees in it's natural position. The designs I've seen available are typically for vertical shift levers.
For about the past 25 years Big Tan has had the transfer case shifter sealed by a thick piece of rubber with a slit ~12" long. It works well enough to seal the air from below from coming into the cab. If worst comes to worst, I'll continue with this. But if others are interested in the same thing, it may be worth considering a custom fabricated part.
Here's a link to some pics if anyone is interested:
'64 Transfer case shift lever and boot
Drop a line if you're interested in getting one.
i need 1 for my 1960 k-20
