11 members (TexasJim50, cmayna, Hotrod Lincoln, WICruiser, Chip O, KCMongo, Jaison, Donf, Woodcmiami, Bill Hanlon, MNSmith), 78 guests, and 2 robots.
Topics128,032
Posts1,055,523
Members48,425
I just bought an NOS ignition switch, GM part # 1997733.
This one is slightly different than my original. This one is a little shorter with a smaller diameter lock cylinder, and has 3 terminals on the back. My original only has 2.
Im guessing that GM superceded the replacements at one time.
Has anyone ever come accros this before?
The Part number stamped on my original reads:1997(rust pit)3.
Im assuming it's the same number.
The third terminal may be an accessory terminal. Did you get a new lock cylinder with the switch?
Harvester
Ya, my replacement comes with an accessory terminal as well. You can ring the switch out, one will be on soon as you turn the key on, the other will come on when you turn it to the start position.
Is your starter still foot actuated or is it upgraded with a solenoid?
The switch came with lock cylinder & keys, they are briggs & Stratton, but they are not the typical briggs & stratton keys you usually see. These ones are round, like tool box keys.
My starter is still foot actuated.
