5 members (Jon G, baldeagle, Nick in Manitou, TexasJim50, Woogeroo), 66 guests, and 2 robots.
Topics128,014
Posts1,055,332
Members48,419
#480216 12/09/2008 5:44 AM
Apprentice
Apprentice
I began to do the interior and took up the rubber floor mat, and underneath was thick rubber piece i guess glued to the metal floor. In some parts of the floor it is comming up and missing. I think I am just going to scrape the rest of it up,so should I replace it with something. If so, What do you recommend?
1964 c-10
65sixbanger #480434 12/10/2008 12:00 AM
Apprentice
Apprentice
If I did not replace it with anything and just left it a metal floor, would it be to Loud?
1964 c-10
65sixbanger #480467 12/10/2008 1:20 AM
depends on how you define "too loud" and what you'll use the truck for .... originally there was a jute/felt underlay beneath the rubber mat - it was great for soaking up moisture and holding it long enuff to rot the floor - some folks use the same thing, some use more modern sound deadening stuff, some use the foil backed bubble stuff, some use carpet ... some don't use anything
Moderated by  ndkid275, Phak1
